Engine Troubles
Old Jul 6, 2009 | 09:19 PM
fignuton's Avatar
fignuton
Default Engine Troubles
Got an 02 fuel injected Road King Classic. Vance & Hines true duals with Samson Rolled Thunder Ovals. Arlen Ness big sucker and Power Commander. Bike has just over 18k miles.
Several days ago I began to hear knocking coming from the front cylinder, near the top. The bike began to stutter and spit through the breather. A bit rough at idle and if idling long enough, will shut down. I don't feel any loss of power but then again, I'm not exactly gunning it. Bike and I are out of commission until I can get this fixed.
Any ideas or suggestions on the cause? Thanks in advance.
Old Jul 6, 2009 | 11:26 PM
bigoscycles's Avatar
bigoscycles
Sounds like it could be the fuel filter or a line leaking in the fuel tank.
Old Jul 7, 2009 | 10:22 AM
the blob's Avatar
the blob
intake gasket leak = motor runs rough, coughs through tb, gets hot then shuts down.
i think that may be it.
Old Jul 14, 2009 | 08:01 AM
fignuton's Avatar
fignuton
What about the knocking that's going on in the top end of the front cylinder? I may go ahead and switch out the air cleaner to the Screamin Eagle or K&N and see if that makes any difference.
Old Jul 15, 2009 | 07:55 AM
rredneckn's Avatar
rredneckn
You may have a lifter going south
Old Jul 15, 2009 | 04:11 PM
SEDELUXE's Avatar
SEDELUXE
yea maybe a lifter going bad...
Old Jul 25, 2009 | 03:31 AM
producer's Avatar
producer
Could be be valve train problem, leaking valve= hot head= bad idle=detonatioin. If it's using to much fuel too, it could be a bad injector or map sensor. bad map sensor may not throw an engine code. Bad map sensor= rough idle=hot engine=too much and or too little fuel= detonation.
rdrisk55
Feb 15, 2019 10:15 AM
George Clark
May 30, 2018 04:45 AM
Buckscent
Apr 2, 2017 04:11 PM
Hi-man
Jun 2, 2013 08:05 AM
FIST_FULL
Feb 21, 2008 11:25 AM
