Woods TW-8 vs T-MAN 625
Dalton' is right.
Folks don't look at too much beside intake closing, but should, is Lobe Separation Angle.
That relationship, and aggressive high lifts, is the Woods cam. But it is noisey. Some are quiter. but still have these same charatorists.
Check that out.
Woods torque cams are about 101 Degrees LSA
The higher power torque cams are 105 Degrees LSA
Then you look at intake closing. And everything else.
A LSA of 101-106
Intake closing of 40-46
Lift of 575-600
Give or take a little. The higher numbers, combined, move things up the curve a little.
Gonna work real good.
Check that out.
A LSA of 101-106
Lift of 575-600
