Question
Old May 21, 2005 | 09:24 PM
Clammy's Avatar
Clammy
Default RE: Question
ORIGINAL: Markcuda
They're duals, no crossover.
I see a cross over in the picture[sm=feedback.gif]
Speaking of crossovers. What's the purpose of them? What would the difference be with "true duals"?
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old May 21, 2005 | 10:14 PM
Markcuda's Avatar
Markcuda
Wouldn'y a xover pipe be a horizontal pipe just under the air cleaner going from the frony cyliner to the rear?
You meen like on a Sportster??????????? That what they have.
Old May 21, 2005 | 11:17 PM
pococj's Avatar
pococj
ORIGINAL: Clammy
ORIGINAL: Markcuda
Cheers!
If the bike has two mufflers, and the left side is being used, the crossover is the pipe running from the rear cylinder to the right side pipe. Usually there is a built-in restrictor in that section. When I made old style 2-into-2 fishtail pipes I'd have to cut that section of pipe in two, grind out the restriction, weld the pipe back together, and plug the piece going to the left side with a freeze plug. The heat shield hid the weld.
The crossover aids scavenging the exhaust gases, and helps prevent reversion. The typical set of pipes will make a bit more power with a properly designed crossover than without.
NickW
Aug 18, 2012 03:02 PM
jim kern
Oct 22, 2008 08:24 AM
Steel
Aug 3, 2007 05:14 PM
Dallastx
Jun 9, 2007 02:02 AM
mean machine
Apr 21, 2007 01:27 AM
