Gear Drive Cam Issues
Manufacturer states that gears shouldn't be used if crank run-out is in excess of .003. What do people like better? That's a matter of opinion, but in '07- later bikes, most will tell you that there's no reason to switch to gears. The hydraulic tensioners are way better than the old spring style tensioners.
There are two options for the early models. You can convert to the '07 up full hydraulic tensioner and roller chain setup but this will require a cam change; the old cams won't work in the new cam plate.
Or, you can go the "hybrid" route with the billet plate, upgraded oil pump, hydraulic tensioners front/rear, outer roller chain but old Morse inner chain. this will allow you to run the older cams.
Either chain drive setup will tolerate more crank runout than a gear drive setup.
gillie64
08-27-2010 06:17 PM
