adjustable se tapperd pushrods question
Just installed 510 mackie gear drive cams and new hyd. lifters'. Push rods are 24tpi instructions tell me 2 1/2 turns from zero lash. Is this right or is it more like 3 1/2 . Stock heads and tc 88. please give me your thoughts. HD TELLS ME 2 1/2.OTHERS TELL ME 3-3 1/2
An push rod with 24 tpi,turned 2 1/2 turns moves about 0.100 of an inch,witch is half of the lifter movement of 0.200 of an inch.So the 2 1/2 turn adjustment is correct. When not sure of proper number of turns to adjust a push rod divide the TPI by 10 and that will give you the number of turns for a movement of 0.100 inch.
Macfhionghuin
Macfhionghuin
The only problem with erring on the "loose" side is to introduce the potential for valve train noise. Many adust pushrods off the bottom; take up full lifter travel of .200" and back off the bottom. Not suggesting that you do it this way but just to illustrate that setting pushrod at precisely .100" of travel is not critical but, IMHO, better to go to 3 turns than 2. More important to let lifters bleed down after adjustment before rotating crank.
Macfhionghuin
Macfhionghuin
Guys, you have to know what the TPI (threads per inch) is on your pushrods! SE Tapered pushrods are 24 TPI, so 2.5 turns after zero lash. Other pushrods such as Smith Brothers are 32 TPI, that is why you hear 3.5 turns past zero lash. Its all about setting the preload on the lifter to .100 If you have some cams with very aggressive ramps, you may need a little more preload to quiet the valve train, but what ever you do, don't go light on preload as one reply said.....can you say valve float?
Like razorsedge says, you need to know the TPI of the pushrod; they vary from one manufacture to another. Hard to screw up following the manufacturer's instrutions but if you want to be sure beyond a doubt, call Andrews to verify the TPI, or check with a thread guage and relax.
