Shovelhead idle problem
I recently bought a 1979 FLH 80" project. Motor had a rebuild about 1000 miles before I bought it. Not sure exactly what, cause the guy I bought it from didn't know much and I haven't yet talked to the guy that did the work. A reputable place though. The bike had the original butterfly Keihin which displayed a number of issues including it wouldn't idle after it got warmed up. It stumbled, pop back through the exhaust and die if you didn't keep the RPM way up. I had a CV carb that I had taken off my 01 Roadking, so I took it apart and cleaned thoroughly. I installed a 50 slow jet, left in the 190 main that was in it and set the air fuel at about 2-1/2 turns out. The bike runs great when cold and will idle down to a slow lope and sounds great. When it gets fully warmed up it still runs great. No hesitation, good acceleration but once hot the idle problem is still there. When it gets anywhere close to a good idle rpm, it stumbles, backfires through the exhaust and dies.
Any ideas? I have worked on a number of twin cams but have little knowledge in the Shovel. Learning as I go. Any help will be appreciated.
Thanks
Jer
Thanks
Jer
Received 47,844 Likes
Thanks
Jer
Thanks
Jer
If your ignition is equipped with flyweights, you very well could have a broken spring, or the weights themselves are buggered.
Same/similar symptoms would be witnessed.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
If it is Dyna S equipped, it has flyweights. Pull the breaker plate, and with a 9/16 socket, remove the screw that holds the flyweights.
Inspect them for broken springs, and the flyweight pivot bores for elongation.
VERY negleted area.
Replace them with the best one you can find, if needed.
If you need one, we carry them.
Scott
VERY negleted area.
Scott
VERY negleted area.
Scott
VERY negleted area.
Scott
Thanks, heading for Sturgis tomorrow so the shovel problem will have to wait till I get back. I ordered new rubber bands and clamps although I really couldn't verify that I have a leak. Adjusted timing didn't help. Ordered new coil which isn't here yet. So i will check the advance when I get back next week. If that looks l;ike a problem I'll give you a call to get a replacement.
