Cam recommendation needed
Lots of info out here on cams...thought I'd ask the forum your thoughts as I start my reaserch.
I'm looking for your recommendations on the best cams to deliver a good combination of torque and HP. I'm looking for your thoughts on the best cams and potentially tuner for the following set up:
Stock 2012 103 engine
Stage 1 ac (Arlen Ness - big sucker)
V&H Dresser Duals
V&H Hi Output Slip-Ons
FuelPac tuner
Any additional thoughts on having it Dyo'ed???
V&H Dresser Duals
FuelPac tuner
What kind of riding are you gonna do , Solo, 2 up, local or lot's of touring...where do you want your power ? low end , high rev...
I don't know **** about cams but the ones that do will want to know this...
You could also call Fuel Moto.. they aren't too far from you...
Thanks all!
I know my bike is a 96" but the Andrews 26H woke it up so nice...I like the low end grunt...You will get a lot of opinions and sorting them out will be one of the most confusing...Lot's of good infermation though...
What i like the most about my cam is when i am in the NC mountains loaded 2 up and i hit a switcback ..i use to have to downshift to ist gear, now i can leave it in 2nd and hit that throttle and she just screams....The range is so much better... www.fuelmotousa.com call them , they are in Little chute WI. 877-729-4754
They do some good work and are very helpful here also....
Quiet operation good torque with some pull up top. Sounds like what everyone wants.
I had a set of WOOD 555 in my 103 dyna. Felt good on the low end and ok up top too. Almost too much torque on the bottom end. This is with the comp 10.6, stock heads squish at .032 .
6th gear on the highway two up wasnt a problem either. People complain about the noise and wood cams but I experienced non, and this is with stock b lifters.
I would stay under .560 lift. also 235-244 duration would be good for you.
I just installed the S&S 570 Easy Start cams. One reason why I went with them was for the built in compression release during start, Makes a big difference on the starter. I've only got a few miles (50mi) on them so far. Take off torque at easy throttle is a little low, but cruising at 2000-2500rpm and cracking the throttle, HOLD On Tight. I didn't want to go with SE cams cause I wanted to get away from ANY EPA mandated rules and yes I've read where some SE cams are not EPA compliant, I just want one that was designed for the best performance with no gov rules even thought of.
Thanks Man, So far its a 80% like on the Wart Hog stickers. Problem is, We (Barksdale AFB) are going to loss our A10's next year (Military Cuts??) and I'll probably have to transfer to B52's. Gonna need a new theme maybe.
V&H Dresser Duals
FuelPac tuner
V&H Dresser Duals
FuelPac tuner
Some are running the SE204 in 103s and are putting up good numbers but the cranking compression gets up over 190psi and tuning and fuel become a challenge which is not something most are prepared and/or willing to deal with.
You will need to 86 the FuelPac and install a "real" fuel management system like the SERT or TTS Mastertune and get the bike on a dyno and tuned.
A cam change is caveman simple and you should consider taking it on as a DIY project.
