TC88 and cam lifter direction??
Funny, I've got the same question. New cam, new lifters. The bike is an '01. Lifter part number = 18538-99. Latest version of number now ends in "C". Service manual states "...with the oil hole on the inboard side and the flats on the lifters facing forward and rearward". Problem is the new "C" lifter, the oil hole is inline with the flats, therefor it can't be inboard. So forward or rearward? Line it up with the holes in the bores? Front lifters forward, rear rearward. Or as stated earlier, does it matter?
He's not my subject matter expert, just a gentleman I happen to know, and I was passing along something he told me in a conversation. (I'm no expert by any stretch of the imagination, just a shade tree hack). The little bit of effort it takes to look at a lifter when it comes out to see which way the oil hole is oriented is all it costs. Obviously if you're using new lifters, this has no relevance whatsoever. There's no "data", just his experience that I was sharing with the forum. You're more than welcome to completely disregard it.
Don't worry about it. If the lifters are stiff, they are primed. If all you are doing is a cam change, there oil passages, lines and galleys are full. Before startup, with plugs out and grounded, spin the starter for a few seconds; a couple of short bursts. Install the plugs and fire the motor up. The valve train may clatter for a half minute or so if the lifters were not fully primed but they will pump up quickly.
