New Lifters ?
Old Feb 2, 2016 | 10:39 PM
johnod's Avatar
johnod
Default New Lifters ?
Installing new lifters, and cams.
I understand I should coat cam lobes with assembly lube.
I believe I also coat lifters and lifter bores.
Do I want to soak the lifters in oil first though?
My guess is yes.
Thanks
Old Feb 2, 2016 | 10:58 PM
Alienwulf's Avatar
Alienwulf
Do all of the above just did mine. I used a oil squirt can on the lifters faster and used less oil.
Old Feb 3, 2016 | 05:28 AM
glidein wide's Avatar
glidein wide
You could pump them under oil with the rod and push out some air, lifters are not assembled dry anyway, not extremely critical. Use assembly lubricant on cam.
Old Feb 3, 2016 | 11:48 AM
Uncle G.'s Avatar
Uncle G.
In my experience, it's not that critical. The tappets are roller tappets, so there's no "sliding" taking place. I just soak the lifters in fresh oil before installing them. I will put a bit of assembly lube on the bushing (outer) end of the cam, and just oil the needle bearing.
The factory manual says to pour a half pint of engine oil into the gearcase before installing the tappet blocks, and I do that, too.
Old Feb 5, 2016 | 11:25 PM
johnod's Avatar
johnod
Thanks all , think I got it now.
Old May 16, 2021 | 12:48 PM
RDFDJD's Avatar
RDFDJD
**Deleting my post** somehow ended up posting in the wrong thread
SoZo
Milwaukee Eight (M8)
Dec 2, 2017 02:21 PM
Kaycee
Engine Mechanical Topics
Aug 13, 2017 10:51 PM
Pops98
Feb 1, 2015 05:05 PM
deuce_streetbob
Exhaust System Topics
Nov 3, 2013 01:05 PM
riley drake
General Topics/Tech Tips
Jan 22, 2011 05:41 PM
