Question about 06 dyna and screamin eagle cams
So the 06 dyna is the oddball because of the updated camchest. I am trying to do a big bore kit on my bike and have been looking at cams first. My question is the screamin eagle 203 cams will not fit my bike right? I need the 204 cams correct
Right. PN 25149-00.
Another question related. I plan on getting these cams to go with a big bore 95 kit. I plan on using stock 103 3 7/8 take off pistons and keeping the hydraulic tensioners. I am not shooting for the most hp out of my motor. I just want a cam that mildy helps the up in displacement. I am not planning on headwork so I don't want anything with a super high lift or crazy stats
I know you say "no headwork" but the 204s like some compression. At a minimum have the chambers measured and shave enough off to set chamber volume at 80-82ccs, use a .030" head gasket and you should see close to 100TQ and mid 90sHP with that setup. The 204s are a very underrated cam.
Of course, you need a good fuel management system like TTS, PCV or SEST and a good tune.
http://www.ebay.com/itm/ANDREWS-ROLL...item20c8b5edb1
The link is to American Classic Motors Ebay store, specifically the Andrews 26 cams but not suggesting you buy them; just wanted you to see that there are aftermarket cams that don't cost $400. I didn't see an add for the 21 cams but call ACM, I am sure they have them at the same price.
The '06 heads were much improved over previous years; a bolt in cam will provide a noticeable boost. Suggest you upgrade the inner cam bearings while you are in the cam chest.
Here is a link to a set of SE203 cams; decent price if you are looking to save a few $$$. Add didn't specify model year; you will have to check.
http://www.****************/forums/s...cams-88-a.html
