how to run conversion cams in SE hydraulic upgrade cam plate
I ordered some new Fueling conversion cams, but have the SE hydraulic upgrade kit (billet cam plate) and have now discovered that the journals for the conversion cams are for a different size (new in 07?). I am talking about the "outside" journal in the cam plate, not the inner bearings (they will work).
Is there any way to run the conversions cams in the SE upgrade cam plate or am I going to have to purchase a new 07 style cam plate??? Looks I am moving from the "upgrade" to the "conversion."
The OEM '07 and later cam plate, PN 25355-06, will work with your conversion cams. You will also need the tensioners, chains, drive sprockets, cam spacers and tensioner fasteners. If the bike is '99-'01, you will need the rear drive sprocket with the trigger ring and will need to block off an oil port.
The parts you are interchangeable between the SE Hybrid plate, the '07 and up billet late or the '07 up OEM plate; your good to go with those parts.
I do not mean to hijack this thread but I just got tottally confused here. I wish to eliminate the inner link chain and go to the newer hydraulic tensioners on my 2005 Ultra. I thought the conversion plate did this. I see it doesn't. What parts do I have to get? Does the oem cam plate from a 07+ twin cam fit my 05 88"? Oil pump also the oem for 07+?
You can go with 25282-11 if you want the billet plate; you would need to order the other parts to complete the conversion since this is an update to the OEM plate and if you were upgrading you would already have the tensioners, chains etc.
The third and cheaper option is to use the '07 and later OEM cam pate and pump. Andrews and Herko used to sell a kit but the MoCo stopped that. Below is the list of parts to make this conversion but you will need "conversion" cams, like the Andrews N series. You can order the parts from an online discount dealer like Newcastle, Chicago H-D, Surdyke, etc. and save some $$$.
I would also suggest the service manual for your bike if you don't have one and that you upgrade the inner cam bearings as part of the conversion; Torrington B148s.
Iron lHorse
Exhaust System Topics
12-13-2013 11:45 PM
