SE II pipes vs Supertrapp
I switched from SE slash cuts to a supertrapp 2 into 1.
Performance is better with the 2in1. It took me a little bit to get used to the change in sound. The ST ships with a closed end cap, and it makes it sound... Swooshy? Instead of a sharp pulse like the SEs. I switched to an open end cap and most of the crack returned. As the fiberglass in the baffle gets dirty, it sounds better and better. It's louder than the SE with an open end cap, but if I don't get on it in the neighborhood, my neighbors don't mind.
Hope this helps with you decision.
