D Carb and 1250cc
Doesn't mean it won't work though, does it? How much bigger is the d? I currently run up to a 187.5 main with the 45. How many mm is the d? They also said I couldn't fit a 1.98 valve in it. But we did. I know the d is prob to big. I'm looking to have opinions on it if I do set it up. What's the worst that could happen. I'm looking to pick up tenths or hundredths in the 1/4
The velocity of that D on a 74" engine will be low, not creating the cylinder fill you'll want for the desired power output.
A B would work, but a D is BIG.
You could try it, as it is free.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Since you do this all the time. How many pump gas 1250cc sportys you putting out that make 1.51 hp per cubic inch?
It's a 1.98 intake valve...not a 1.94. Not a huge difference. But it's still bigger. I don't care about falling on its face under 6000 grand. Cylinder fill is max at 6200 I assume since that's where it peaks the tq. Im looking to squeeze more power out of the big end.
