JavaScript.
I haven't been able to load this site for the last several months. It simply won't open all the way(partially load and freeze). I also had this problem a number of months back, but then it magically started to work. Well, I discovered a solution and that is turning off JavaScript. Since I did that the site has worked flawlessly. As a test I turned JavaScript back on and sure enough the site won't load. I don't know whats going on here, but I can tell you that this is the only website/forum that I have this issue with.
Some dilegent IT guy might want to have a look at what's going on behind the scenes on this website..
PB
PB
