Stage 2 big bore for 04 road kig custom
Should i or shouldn't i.I have been given opnions that a stage 1 and a diff cam s eagle 203 would be fine.I still wounder about the extra tourqe and hp. Also please give opnions about samson exhaust vs vance and hines.</P>
Thanks</P>
I can't believe no one answered your question! Is no one here interested in power, or is this board for posers.
If you haven't already done the conversion, I would highly recommend it. The increase in torque is huge, for a warrenty freindly and relatively inexpensive modification. If you go to www.nightrider.com and click onto the motorcycle performance link you will see comparisons of a all kinds of engine mods that are real, with actual dyno results. One look at a 95 cube with cams, breather, V&H slipons and a Efi map upgrade, and you will be running to the dealer to order parts.
