New '24 Breakout, loose fork stem screw
Hey folks... I'd appreciate it if any of the wrenchers could give me some input here. I just noticed that the washer around the fork stem screw on my 2024 Breakout was spinning freely, and the screw itself was quite loose.... not finger loose, but definitely not where it's supposed to be. I torqued it to spec. The pinch bolt just below that washer was torqued properly, but there's a pretty big gap there. Is that normal? Bike is new, ~850 miles on her. No noticeable handling issues. Was planning on taking it in for the 1K service this weekend anyway. I will definitely be mentioning all the above when I take it in... just not sure how big a deal I should make of it, if at all. I'm no mechanic, but it is the steering column... I like the bike to go where I point it 🤣
Thoughts?
The center bolt is used to preload the steering head bearings. There isn't a spec to tighten it to, it's tightened or loosened to get the correct steering head bearing adjustment. Having said that after I adjust the bearings, and tighten the pinch bolt, I do snug the center bolt down so it doesn't vibrate loose. You can completely remove the center bolt after the pinch bolt is tight, it doesn't do anything at that point. It's not HD at its best, virtually every other manufacturer uses a double nut arrangement for the steering stem.
"Fork stem screw, 1st torque 160-168 in-lbs, loosen, then final tighten fork stem screw to 62-68 in-lbs."
Maybe it's not accomplishing anything, but there is a procedure for it. Who knows...
Thanks!
We are slowly getting on the same page because I found the torque values for assembling the front end that you listed above for my bike in the manual. I wasn't aware of the procedure because It isn't part of the check and adjust section, thanks.
Now back to the bolt. It's function is to draw the top triple clamp down to take up the play in the bearings and establish bearing preload. When you tighten the top tree pinch bolts that Is what holds and keeps the thing together.
Someone in engineering at HD is a cyclist because this is exactly how a Threadless Stern functions. The center bolt is there to affect the adjustment only. The stem pinch bolts are what keep the assembly tight.
You could put a dab of blue loctite on the center bolt. Just make sure your bearing adjustment stays correct and it really is just the center bolt vibrating loose. Is there undue vibration?
Redbeardtheweird
11
09-28-2021 02:02 PM
