Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
tuning springer front forks
Old 02-22-2005, 06:34 PM
SPRINGER's Avatar
SPRINGER
SPRINGER is offline
Received 3,270 Likes on 1,976 Posts
Default tuning springer front forks
I have heard somewhere that the front forks of a Springer need to be tuned after initial breakin period. Can someone please explain about the tuning of the front fork and why? thanks
Old 02-23-2005, 07:13 AM
investorsc's Avatar
investorsc
investorsc is offline
Default RE: tuning springer front forks
You can tuna piano, you can tuna radio but you can tuna fish...........OK it's early.
I first need to admit ignorance if there is a better answer. All I know is that the rate on a springer is controlled by the torque or turns on the compression nuts for the springs. THe shock on the Harley springer front end serves as a dampener, and help remove oscillations from a bump. Depending on riding style, the springs seem to take a set, and you may need to retorque or check the nuts to give the "ride" you are looking for. Adjustable rate is based on spring compression or squeeze.
My .02
BRUCE
Old 02-23-2005, 04:15 PM
SPRINGER's Avatar
SPRINGER
SPRINGER is offline
Thanks Bruce, I think that I understand what you are talking about. I was trying to figure it out in my own head, but I didn't have enough info to work with. THANKS
Old 02-25-2005, 10:25 AM
Sincecrazy's Avatar
Sincecrazy
Sincecrazy is offline
Damn investorsc, that sounded really professional (I like to tuna fish), and to think that it was an early morning reply.
cdj
Custom Models
09-25-2018 02:01 PM
edjack
04-02-2014 11:51 PM
donovann2o
04-20-2011 12:54 PM
pwarrick
08-25-2006 01:01 PM
Skip
08-08-2006 08:49 PM
Quick Reply: tuning springer front forks
