94 fatboy front wheel
Hi was wondering if some1 can answer a question i bought a 94 fatboy front wheel and it has a thin spacer in the wheel hub sitting against the wheel bearing which i can pull out with my finger. then the speedo dirve would go against that.The only problem is the diagram of the wheel does not show a spacer before the speedo drive.would anyone happen to know if there is a thin space in the wheel hub or does the speedo drive go onto the wheel with no spacer on that side?Thanks
