fatbot front wheel spacer
Old Feb 1, 2008 | 02:58 PM
jammer1's Avatar
jammer1
Default fatbot front wheel spacer
Hi was wondering if some1 can answer a question i bought a 94 fatboy front wheel and it has a thin spacer in the wheel hub sitting against the wheel bearing which i can pull out with my finger. then the speedo dirve would go against that.The only problem is the diagram of the wheel does not show a spacer before the speedo drive.would anyone happen to know if there is a thin space in the wheel hub or does the speedo drive go onto the wheel with no spacer on that side?Thanks
Old Feb 1, 2008 | 03:12 PM
riden2low's Avatar
riden2low
Default RE: fatbot front wheel spacer
I just had my wheel off...93 fatboy...and I am thinking thats the way it is set up......but you have a spacer on the other side.
Old Feb 1, 2008 | 03:19 PM
jammer1's Avatar
jammer1
yes i know the is a big spacer on the other side but i cant figure out why there would be a spacer on the side of the wheel were the speedo drive goes.I have a manual for a 92 softail and for solid wheel it dosent show a spacer on the speedo side.And i am assuming the wheel is the same untill 96 when they removed machanical speedo
tsobash
Jul 1, 2017 10:32 PM
misfitJason
EVO
11
Jan 12, 2017 07:09 PM
backonharley
Wheels/Tires
Sep 13, 2016 10:34 AM
dodgeman568
Wheels/Tires
Jan 15, 2013 07:44 AM
jammer1
Feb 1, 2008 10:41 AM
