bleeding front brake (jaybrake)
RE: bleeding front brake (jaybrake)
Try gently tapping the brake line with handle of screwdriver to work the air bubbles up into the brake cylinder. Put one end of a clear rubber hose over bleed valve and other end submerged in jar with brake fluid in it. When bleeding, open bleed valve, slowly squeeze brake lever, close bleed valve, slowly release brake lever. Repeat this sequence until no more air bubbles come out bleed valve.
I wish it was as simple as you say... I have gone back from one side to the other 6 or 7 times and still a soft front brake lever. It will pump up if you squeze it a few times, but let it go 5 seconds or so and it back to the grip again. I have tried both with and without the top on the reservoir.
I just installed aHawg Halter front caliper and the only thing that worked for me was to leave the cover off the master cylinder resevoir for about 4 hours so all the air could slowly work it's way up the line. The resevoir was full of DOT5 fluid. When I came back I had a pretty firm lever but it still needed to be pumped a few more times to get the rest of the air out.
I don't know why this worked when I couldn't get the air out with the cover on, but a friend suggested that I try it and it worked for me.
If it hadn't worked, the next step was going to be forcing clean fluid into the caliper bleed screw with a big syringe and a clear tube in hopes of driving the air up and out throught the master cyl.
When I have that happen I leave it overnight with the handlebars turned to the left (elevate the master cylinder). The system usually bleeds itself that way.
If you run jaybrake calipers, call jaybrake and they will tell you how to use a syringe to force fluid through the little holes in the master cylinder.
Try this, it worked great for me. Had lots of very tiny air bubbles. Now I have firm brakes. I have bled literally thousand of brake systems, and this was the trickiest ever.
http://www.moccsplace.com/images/bra...er/bleeder.htm
