Knocking in front end
Wide glides with single disc brakes have a tendency to tweak under hard braking and have a distinctive "knock" is how I describe it. If it's clunking when hitting a hole I'd have to see if it's bottoming out. Take a zip tie and put it around the fork tube just above the lower dust shield, tight enough to not slip around by itself but not to tight. Go for a ride til you hear the noise and see where the zip tie is on the fork tube. Then hold the front brake or put the front tire against a wall and try to compress the forks till they bottom and see if the zip tie indicates that the forks are bottoming out. If they are try heavier weight oil in the forks.
Since you have nothing in your signature, no one knows what you're working with.. What year and model??
First thing that comes to mind is, steering head bearing needs to be re torqued, then I wolud have to look at the washer in that steering head. If it's Dyna, like an 07-08, there was a TSB to replace it with the thicker one, then re torque bearing. I would also look at the gas tank mounting bolts/nuts, ensure they are tightened. That too has been known to create the knock noise you're hearing. Got a windshield?? Check the mounts...
