Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Slider interchangability
Old Aug 30, 2011 | 09:50 PM
CamFX's Avatar
CamFX
Default Slider interchangability
Redoing the front on my blue chopper (see pics) and got a killer deal on some 49-77 style 41mm fork tubes. The sliders (or lower legs) that would normally be used either came with drum brakes or banana caliper mounts. Since I really would like modern braking (and vintage sliders are expensive) does anyone know if the more modern sliders would interchange? I got the fork tubes brand new and the exact length I want for $20 so you see why I want to use them if possible.
Old Sep 13, 2011 | 02:32 AM
TwiZted Biker's Avatar
TwiZted Biker
No pics came through man . The tube you bought will not work with 84 and up legs the damper assy. is different and the leg inside dia. is wrong , been there and have a nice selection of those early tubes new in several lengths . You can add aftermarket disc brake setups to the early legs GMA has a couple ways to go for them or if your a bit creative you can adapt things yourself , not that hard with a few tools and a bit of ingenuity .
cliffster
Dec 6, 2020 07:11 PM
lllFIGJAMlll
Mar 4, 2014 09:16 PM
cgtrigg
Mar 14, 2012 09:43 AM
SUUIE
Jan 9, 2012 11:12 AM
FL-kruzen
Oct 23, 2011 08:52 AM
