Rake, Extended Fork Question on Heritage
Sorry for this ignorant question, but I am confused!
I am getting ready to put on a HHI 4* triple tree which has 2" extension plugs allowing the use of the stock fork tubes. I have read on this forum of others doing this and also using additional 2" over tubes, then they use a front lowering kit to bring the bike back to level.
Why are they doing this combination of extended tubes and lowering kit, rather than just staying with the stock tubes that HHI says will bring the bike back to level with their 2" extension plugs?
Any enlightenment would be appreciated!!
I think a lot of people do it the way ya described so there is more leg in the fork tube, reducing possible binding problems. On cycles w/ a longer front end & greater rake the travel of the suspension changes some what, sort of like applying weight to the middle of longer steel rod compared to a shorter steel rod, obviously the longer rod bends more easily; that cycle in yer avatar has a fairly shallow rake to begin w/ & I don't know that you'll want the extra length--I suggest asking HHI if they suggest using the method you were describing.
TriGeezer
06-21-2017 06:38 PM
