Fuel Moto / Jackpot Mufflers USA's leader in EFI tuning and exhaust systems.
Fuel Moto Cam Install kit $49.95
Old Oct 17, 2011 | 04:31 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Default Fuel Moto Cam Install kit $49.95
For those of you that are swapping cams on your Twin Cam motors Fuel Moto offers a cam install kit which includes all necessary gaskets and orings, as well as Torrington inner cam bearings. Here is what is included in the kit:
(2) Torrington inner Cam bearings
(2) Gasket, Rocker Cover, Metal w/ Bead
(2) Gasket, Breather Assembly, Cover
(2) Gasket, Breather Assembly, Baffle
(2) Gasket, Tappet Cover, Front & Rear
(1) Gasket, Cam Gear Cover
(4) O-Ring, Pushrod Tube, Center
(4) O-Ring, Pushrod Tube to Tappet Block
(5) O-Ring, Pushrod Tube to Cylinder Head
(2) O-Ring, Lower Rocker Cover to Cylinder Head
(1) O-Ring, Oil Pump, Outer
(1) O-Ring, Cam Support Plate
(2) O-Ring, Oil Pump Inner
(2) Seal, Umbrella Valve
(2) Filter Element, Breather Assembly
We also offer packages with Wood's cams, FM adjustable pushrods, and the FM cam install kit, you can contact us for more details at 877-729-4754
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Mar 23, 2013 | 10:52 PM
Rick1981's Avatar
Rick1981
What is the part number? I could not find it on your website.
Thanks
Old May 2, 2013 | 10:18 PM
misfitJason's Avatar
misfitJason
Just wanted to say that I purchased this for a cam install. Kit is rad and a great value
DXHD $100
Jan 1, 2014 07:31 PM
mattVA
Aug 29, 2013 05:10 AM
UltraNutZ
Exhaust System Topics
Sep 28, 2012 12:00 PM
SICKBAGGER
Apr 4, 2010 06:32 PM
