Lean noise
Old 10-05-2014, 08:12 AM
sjef's Avatar
sjef
sjef is offline
Originally Posted by edilgdaor
It's the front differential. The CV joints went bad and caused the front differential to leak.
You're assuming the bike is all wheel drive?
Old 10-05-2014, 08:26 AM
K Melancon's Avatar
K Melancon
K Melancon is offline
I have gotten use to this when tires start to cup or worn down. 2011 FLHTK I had 26,6??.? Miles on original tires with no cupping, just wear. I was getting a wine when leaning also so I thought it was worn tires. I was getting ready to replace them in another 2,000 miles after I returned from a trip. Shop had a sale going before the trip so I went ahead and purchased the tires. Waiting on them to finish and service guy comes out and tells me that the front wheel bearings are bad and needs replacing. I just had the rear bearings changed last year. I don't understand why put crappy bearings on these bikes. I have never had a bearing go out on any of my bikes and this thing eats bearing. And NO it has never seen a pressure washer and stays in a garage.
Old 10-05-2014, 10:33 AM
dribble's Avatar
dribble
dribble is offline
Originally Posted by DanHappy
That's nuts!! What would cause that ? Too long under pressure?
Interesting the reason for this noise. I will check the tire pressures tomorrow.,what is good pressure to run for touring bike?
Sent from my iPhone using IB AutoGroup
I don't know. I've always kept up the pressure at 40 PSI. Ride two up mostly. When I bought the bike from the dealer in Montana, they told me that they put a new tire on for the original owner at 5K (I assume for the same reason). My wife and I combined weigh 325 lbs. I'm just going to install an Avon tire and see what happens. I'll get at least 5K out of that one and I hear they stick like glue so why go with the Dunlop again.
Old 10-06-2014, 06:26 PM
slapshot12's Avatar
slapshot12
slapshot12 is offline
Cupped tires....mine did the same thing with barely 10k on them. I replaced the stock tires with Michelins and I'm very happy with them so far.
Old 10-06-2014, 07:19 PM
tenn volunteer's Avatar
tenn volunteer
tenn volunteer is offline
Check wheel bearings, they will whine as well. Mine were replaced at 32,000 miles under warranty. I also changed the back tire at the same time because of cupping. 7.000 miles on a 407 Dunlop. I got 18,000 miles on the previous back tire. 6 days of riding all day in extremely hot weather. Indicated over 100 degrees on OAT gauge.
Old 10-06-2014, 07:56 PM
FXDXTSport's Avatar
FXDXTSport
FXDXTSport is offline
Originally Posted by 1Canuck
The sound is from the tire starting to cup. add 2-3 lbs air, make sure the gauge you are using us accurate.
Or it could just be low tire pressure. I had this once when my pressure was down to 31 in the front instead of the 35 it should have been.
Byron Loyd
09-05-2016 08:04 AM
Riven02
09-10-2013 10:31 AM
Kevin Rollert
08-24-2012 11:50 AM
hfdarson1
07-27-2011 12:01 PM
ctcruiser
Wheels/Tires
06-19-2011 12:38 PM
Quick Reply: Lean noise
