Hand starting a old harley
Old 12-19-2014, 08:32 PM
TAHOE GUY's Avatar
TAHOE GUY
TAHOE GUY is offline
Default Hand starting a old harley
Ever seen anybody do that before ? I did years ago. This skinny friend of mine could do it with his 70's model kicker shovelhead dresser. First try. Will never forget it.
Old 12-19-2014, 09:44 PM
ngshop's Avatar
ngshop
ngshop is offline
I used to do it all the time when I worked at the HD dealership from '71 til '79.... don't tell it often as most people now days tend not to believe you. I want even mention loading a full dressed FLH into the bed of a pick-up truck alone and with no ramp...... The dealership owner used to win $20 bets laying said dresser on it's side and raise it upright using one finger. Sounds like tall tales huh! all true.
Old 12-19-2014, 10:33 PM
TAHOE GUY's Avatar
TAHOE GUY
I believe you. Great reply.
Old 12-19-2014, 10:53 PM
dgdamore's Avatar
dgdamore
dgdamore is offline
Cool story bro.
Old 12-19-2014, 11:05 PM
Hocus-Pocus's Avatar
Hocus-Pocus
Hocus-Pocus is offline
Very similar to starting an old model A, just gota have the pistons in the right place.
Old 12-19-2014, 11:15 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Stock compression. Sounds like its possible.
Old 12-19-2014, 11:23 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,968 Likes on 17,493 Posts
Till I went 93" hi compression I could push my 88" shovel through by hand and start it , she was a tired 9-1 just had to have a good tune and know the bike. Seen 12 yr olds kick them.
Old 12-19-2014, 11:26 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
It's more than possible. Used to do it at every Rally that had a Kick Start Contest. A well used old Panhead. Get it up and centered on the compression stroke and push down hard. Voila! Varoooooom! Puckata Puckata.
Old 12-19-2014, 11:32 PM
soft 02's Avatar
soft 02
soft 02 is offline
Wasn't insinuating it was not possible. I have a twin cylinder welder in my shop that is hand crank only magnito. 8.5-1 Like to see someone hand crank a 12-1 by hand.
Old 12-20-2014, 06:00 AM
Sling Blade 14's Avatar
Sling Blade 14
Sling Blade 14 is offline
Received 1,789 Likes on 931 Posts
My old '53 Pan was timed so well I could do that.
It was stock, 6 volt, with a very manageable compression.
74 cubes.
Quick Reply: Hand starting a old harley
