Holes in air filter...
Anyone have this happen to them? I noticed today that there are about 5 holes in my air filter ranging from about 1/16 inch to about 1/8 inch where I can see all the way through the filter material. I have the SE Ventilator with the filter that came with it that is supposed to be washable but I have only washed it twice and the material is already coming apart. My question is are there any auto parts stores or anywhere you guys know of that I can get a replacement locally? I already have one on order through the dealer but don't want to wait for it to come in before I can ride again. This seems like a really dumb problem to have and I'm surprised the dealer doesn't stock them. Any help is appreciated as always.
OEM filters in HD's are not washable per HD. However I have developed a way to get them clean for about three uses.
First spray the filter element on the inside with WD-40. Set for awhile. Then pour a hot mild soap solution through again from the inside. Rinse with hot water. I gently blown air through from the inside. Set overnight to dry. Inspect the element looking through it in front of a light source.
I have found by the second or third cleaning some clear areas come up. At that point I install a K&N.
This isn't the OEM filter. It is a screamin eagle ventilator. I thought they claimed that the filter element is washable. But I guess not.
