Denmark ask upgrade to Brembo Flht 2001
Old 11-15-2015, 06:05 AM
bornholm's Avatar
bornholm
bornholm is offline
Default Denmark ask upgrade to Brembo Flht 2001
Can anybody help me?
I own a 2001 Flht Electraglide Standard.
I Will upgrade my front brakes,with Brembo parts.
I have a set new brembo floating rotors 11,5" model Oro.
Can i use this rotors,or must i change Them and buy 11,8"?
What year Calipers Will fit? (Heard that only 2008 Will fit?
And Can i use my old brake Master,and brake Lines?
Hope someone Can give me the answer,and Maybe someone have something for sale?
Thanks
Lars
Old 11-15-2015, 06:53 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
Brake calipers must match the rotors in order to work. It will not matter if your old caliper & rotor combination is 11.8 and you change the caliper and rotor to 11.5.
Old 11-15-2015, 10:40 AM
bornholm's Avatar
bornholm
bornholm is offline
Thanks for the answer.
Can someone Tell me What i need to buy,when i Will upgrade my old Harley brakes?
I have only the Brembo floating rotors 11,5" brandnew,but the dealer Can change Them so i have 11,8" rotors as i heard is the right Size.
Witch year Of Calipers Will fit? (All models 2008-2014) or only 2008 calipers
And do i also need brakelines and Master?
Hope someone Can help so i not buy a lot Of parts,and so i cant use it.
Thanks
Lars
Old 11-15-2015, 12:02 PM
tommyglide's Avatar
tommyglide
tommyglide is offline
Bornholm, qtmi.com in California has bracket and calipers to fit your rotors. I dealt with them this summer, amazing customer service an knowledge.
Howard at Motorcycle Metal on this forum also does this kind o stuff but I came across him after the fact. Good luck and you will like the Brembo calipers
Old 11-15-2015, 03:32 PM
Remi_357's Avatar
Remi_357
Remi_357 is offline
i started this project but never finished it. here are the parts you will need
brembo calipers
11.8 rotor
brembo master cylinder with brake lever
clutch perch with lever
brake lines
the correct dot brake fluid.
the original master cylinder and lines will work but you will not get the full benefit of the brembo upgrade. I highly suggest you use the brembo master cylinder. the old brake lever will not fit the new master. The 2001 clutch perch does not match the brembo master so youll need the perch as well. Parts can be 2008-2013 as i recall.
also keep in mind the 2001 and brembo uses different brake fluid that does not mix so you need to be sure to get all the old flushed very good
01fxdxt
EVO
05-08-2016 11:25 AM
HGM
EVO
26
11-23-2013 06:34 AM
pacemakertom
06-29-2012 06:31 PM
americanthunder
Touring Parts
07-03-2009 12:46 AM
Fla Glide
12-10-2007 06:33 AM
Quick Reply: Denmark ask upgrade to Brembo Flht 2001
