Bouncing voltage gauge
Old 11-25-2015, 04:29 PM
Whodattom's Avatar
Whodattom
Whodattom is offline
Default Bouncing voltage gauge
My 2010 Streetglide's voltage meter is bouncing sometimes when the bike is moving. Seems to stay steadywhen at idle or stopped. Any body else seen this before? New gauge or hopefully there is a way to fix...
Old 11-25-2015, 04:38 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 22,040 Likes on 8,474 Posts
Could be loose connection on the back side of it.
Old 11-25-2015, 06:02 PM
jack6hd's Avatar
jack6hd
jack6hd is offline
+1 or anywhere on circuit
Old 11-25-2015, 06:44 PM
LoneRiderFLH's Avatar
LoneRiderFLH
LoneRiderFLH is offline
Voltage regulator?
Old 11-25-2015, 07:24 PM
Curlybill's Avatar
Curlybill
Curlybill is offline
My bike did that just before the regulator went.
Old 11-25-2015, 08:23 PM
31scout's Avatar
31scout
31scout is offline
Check all your connections, then check the voltage regulator. If you google "how to check a harley voltage regulator", you'll come up with pages that tell you exactly how to use your multimeter. You will need a good multimeter that has a "capacitor" setting on it for 1 of the tests you'll be required to do. A good Fluke multimeter will have what you need.
Old 11-26-2015, 08:20 AM
havenolife's Avatar
havenolife
havenolife is offline
I know this is going to sound crazy or off the wall but it may be a bad front wheel bearing it would not be the first time for that to be a sign it would not take much trouble to pull the front tire off and check it
Old 11-26-2015, 08:53 AM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,485 Likes on 1,543 Posts
please explain how a wheel bearing is related to the charging system.
Old 11-28-2015, 06:10 PM
zeman1's Avatar
zeman1
zeman1 is offline
Default Bouncing Needle
Had same thing on my 2005. Turned out to be loose negative cable on battery. Check simple stuff first.
Old 11-28-2015, 06:28 PM
1004ron's Avatar
1004ron
1004ron is offline
I'm also keen to learn something here.
Quick Reply: Bouncing voltage gauge
