Thicker Shifter Pegs
Old 12-16-2015, 06:47 PM
Sammi's Avatar
Sammi
Sammi is offline
Originally Posted by E8USMCRET
Check www.innovativemotorcyleaccessories.com Ron has some cool stuff and maybe what your looking for.
Thx, i'll give it a look.
Old 12-16-2015, 10:20 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Originally Posted by Sammi
Bike has original shifter rod for stock '06 low Rider (fitted with one shift peg) and it is not adjustable.
Buying an adjustable rod could do it. Thanks for the tip.
SAammi
Wait, I didn't catch this until now. Please feel free to school me if I am wrong, but is sounds to me as if your dealing with a bunch of aftermatket parts here. Again, I may be wrong as the last Low Rider I owned was a 1996, but I was under the impression that ALL Low Riders, from the beginning of time..... way back even when they were Shovels, were mid control bikes. Low Riders never came with forward controls? Cause they were marketed towards , you know, SHORT PEOPLE? Am I wrong?
Maybe you are just dealing with some aftermarket, or dealer added stuff. I can PROMISE you, my 1996 Low Rider had Mids, cause that was the very first mod I did. Swap to forwards.
Old 12-16-2015, 10:36 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,893 Likes on 4,708 Posts
Harley makes forward controls for the dynas, as well. But yes hes put them on or somebody has
Old 12-17-2015, 09:39 AM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Ok, that's what I thought. And that would explain the lack of adjustable rod.
Old 12-17-2015, 05:45 PM
Sammi's Avatar
Sammi
Sammi is offline
Didn't intentionally try to cloud the issue. To clarify: I bought an '06 Low Rider new, had H-D forwards installed by an Indy, and now using H-D heel/toe shifter fabricated with H-D Softail parts. Pic of my shifter attached. I will look look a bit more for a larger diameter shift peg, and plan B will be to check adjustable shift rod.
Thanks for all the suggestions.
p.s. bikerlaw, You are wrong, Low Riders are marketed to Cool People.....
Sammi the Gimp LOLOL
Old 12-17-2015, 06:51 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,977 Likes on 3,049 Posts
I'm missing something. Why can't you just remove the front shift arm and put it back on lower on the splined shaft?
Old 12-17-2015, 09:57 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
LOL. My bad. I apologize. You are correct!
You know whats funny, is I remembered only because I did the EXACT same thing to my Low Rider many years ago.
Ranger, the splines offer only so much adjustment. One spline is a lot of movement. Without the fine tuning of the shift rod, it's either way up, or way down.
Old 12-18-2015, 06:20 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Thankx for clarifying, the spines on mine are small so it's a finer adjustment.
vtdiesel
05-04-2015 08:34 PM
gsxrboy96
03-29-2012 02:10 PM
dgriffith
05-12-2008 05:03 AM
odog
10-03-2007 09:42 PM
Qball
06-25-2007 06:57 AM
Quick Reply: Thicker Shifter Pegs
