Mapping your bike
Wow, I get a kick out of that response,, he say's;
No it doesn't matter what temp it is outside but it does matter what temp the air is coming into the engine.
Think about it flyboyron, Are you going to only run the bike when it's the same temp as the day you mapped it?
Sure it will matter if you do it on the coldest day of the year in your area and/or the hottest, just use a little common sense.
An ambient temp swing of say 40-50° won't matter as much as large elevation changes as long as the engine is at running temp.
Received 5,406 Likes
When tuning anything the variables affect the mapping. Temperature, humidity, atmospheric pressure, fuel pressure, etc. All you can do is try to stabilize it the best you can for the conditions you will run in the most.
FWIW the automotive tuning I used to do was under real conditions, dyno time was only remotely good for WOT runs, drag racing, or bragging rights.
