Will primary oil warm up by idling?
Received 8,252 Likes
part of the reason to change oil is to remove the contaminates and condensation within the system, along with particulates, junk, and gunk. 10 mile ride is best, it will insure you have as much of the crap in suspension and ready to drain. if you do an idle warm up, you won't get nearly the same result. But.... depending on your total situation and frequency in changes, I would consider a good warm up and drain if I could not get a few miles on it. So yes, you can idle, warm up, and drain. just be aware a good ride before is much better!!!
Received 4,251 Likes
The following 3 users liked this post by YeOldeStonecat:
and like stonecat says, 3 or 5 screws. not a big issue. then you know it's done right.
SFinley70 (05-27-2020)
