Flat Tires $ Bad Luck
Old 06-03-2016, 08:04 AM
Tampa Fatboy's Avatar
Tampa Fatboy
Tampa Fatboy is offline
Received 10,432 Likes on 4,751 Posts
Default Flat Tires $ Bad Luck
Rear tire was getting bald so I figure I’d let the local HD shop replace it. Less than 50 miles later my rear brake went out. Yanked the caliper to find a bent spring. I had to wonder about that one.
Anyways, less than 300 miles later I’m pulling into one of the other local HD’s to pick up ‘o’ rings and a derby cover gasket. I come out to the scoot and go to take off to rear flat tire. Frigging nail in the tire, one of those things they use to hold coax. It was a Monday which is a HD service nightmare. I sat there 5 hrs.
First dealer hit me for $400, second dealer was $325. Same owners,different stores. Needless to say we won’t be going back to the first store. Talk about a couple of weeks bad luck. Got to laugh about it and move on.
Old 06-03-2016, 08:09 AM
QC's Avatar
QC
QC is offline
Received 19,790 Likes on 9,863 Posts
That stinks, dude. Hope your luck takes a better turn.
Old 06-03-2016, 08:23 AM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,073 Likes on 2,557 Posts
Flats tires. I only have two words...RIDE ON. It seals tire punctures AND balances them. I had a nail in my back tire and the tech pointed it out to me. He said it wasn't leaking air and I told him I had Ride On in them. So I know it works.
Old 06-03-2016, 08:33 AM
Bluraven's Avatar
Bluraven
Bluraven is offline
+1 on Ride On
Old 06-03-2016, 08:49 AM
Bluesrider.df's Avatar
Bluesrider.df
Bluesrider.df is online now
Received 1,675 Likes on 941 Posts
I have Ride On in my rear tire, and heartily recommend it. Unfortunately my front tire is spoked (inner tube), and RO isn't too effective with those. I like the look of spokes, but my next bike will be cast wheels because I really want RO in my tires. Being able to take a puncture and pull over safely, or even ride home safely, it a very big positive.
Old 06-03-2016, 08:50 AM
Bluesrider.df
flhtc02 (06-07-2016)
Old 06-03-2016, 09:45 AM
Roster's Avatar
Roster
Roster is offline
My $250 souvenir, went straight in center of tread small end first. Had about 1k on the tire. Bugger.
Old 06-03-2016, 09:53 AM
Bluesrider.df
At least you got a free Leatherman out of the deal.
Old 06-03-2016, 11:13 AM
cdestuck's Avatar
cdestuck
cdestuck is offline
Where are you guys buying Ride On? Is it tough to get it into the rear tire while it's on the back of a Ultra and should this be put in before or after getting a flat. Tks.
Old 06-03-2016, 11:21 AM
Bluesrider.df
I bought it on Amazon, a 2 bottle pack. They have different formulas, you'll need the one specifically for motorcycles. Easy to install, you remove the valve stem to let air out of the tire, add the amount directed, and reinflate.
cdestuck (06-05-2016)
Quick Reply: Flat Tires $ Bad Luck
