passing lamp lens cleaning?
The service manager at the local HD dealership gave me a recommendation years ago when that cloudy appearance starts. He said to simply remove the bulb & wiring from the rear of the lamp you wish to clean (headlight or passing). Pour a small amount of isopropyl alcohol (rubbing alcohol) through the opening in the back. Gently swish the solution around for a few minutes, turn the unit upside down and drain out the fluid. Allow about an hour or so for the remaining alcohol to evaporate and then reinstall the harness/bulb/wiring back in.
I have used this technique when I had my 2004 Low Rider and used it again with my newer 2014 SGS. Works like a charm every time.
Good luck.
Good luck.
I use the 14 step method:
1) remove light housing from bike
2) remove the bulb from of the light housing
3) tape a small piece of terry cloth on the eraser end of a pencil
4) spray the cloth with Windex
5) insert the clothed windex soaked pencil into the light housing
6) swirl the pencil around in a clockwise direction
7) reverse direction and swirl the pencil around in a counter-clockwise direction
8) once lens is clean, remove pencil
9) re-install bulb into the light housing
10) re-install light housing on bike
11) wait until dark to take bike out on a ride
12) ride bike to nearest bar
13) drink a beer to celebrate your accomplishment in cleaning your lens
Good luck.
Good luck.
