After new clutch cable was installed now jumps in gear
Received 14,177 Likes
It's the clutch adjustment, maybe not the cable. Go on youtube and watch clutch adjustments. Usually, biggest problem is most do do not get the burrs off the adjuster screw and the think they are at no play when the do back off at the clutch. That way, there is too much slack to pull in clutch that breaks apart the drive and driven disks. They also tend to stick anyway. We can talk you thru this but first study so you have it in your head how it works. Soft tails, Dynas and Big cruisers are the same. Sportys are opposite but work similar. Also make sure you have a stock clutch. Do not try to compare apples and oranges.
For some model years there is a recall for this issue (I believe)
Click here and enter your vin
Edit: My bad, thinking new bike issue. Nevermind
Sounds like your clutch is not adjusted to me, you can't just put an new cable on and not adjust it
how much 'jump' are we talking about here? if your clutch fluid is cold, there is a certain amount of 'stiction' in the plates and your bike will jump forward just a little when you put it in gear. it's only a slight jump, not continuous like your clutch is still engaged, your brake should have no problem holding it, and is completely normal.
