What's the ticking?
Old 02-26-2017, 09:55 PM
chaselee's Avatar
chaselee
chaselee is offline
Default What's the ticking?
My son asked me to take him around the block this evening. So I backed the softy out of the garage and fired it up. I immediately heard a ticking sound coming from the front of the motor that I've never heard before. Sounded like an exhaust leak or a lifter tick. I let it idle for just a sec and we jumped on headed around the block. I got a couple streets over and it went away. I recently put new bassani pipes on so I thought maybe an exhaust leak even though I've not heard it to this point (new pipes have been on over a month).
I guess it concerned me a little because I've not heard it before and it was a pretty damn loud tick. And I've riding the bike to work probly 300 miles this week without hearing this noise.
Old 02-26-2017, 09:57 PM
RK4ME's Avatar
RK4ME
RK4ME is online now
Received 2,222 Likes on 1,385 Posts
Did you check all the mounting bolts?
Old 02-26-2017, 10:08 PM
chaselee's Avatar
chaselee
chaselee is offline
The only bolts I checked were the header bolts and they were tight.
Old 02-27-2017, 12:32 AM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,071 Likes on 2,555 Posts
Lifters is the first thing that comes to mind. But I'm not a mechanic.
Old 02-27-2017, 12:34 AM
chaselee's Avatar
chaselee
chaselee is offline
Me either. Thing that tripped me out was that this was the first time I've heard it. And I've rode it quite a bit this week.
Old 02-27-2017, 05:50 AM
touchdown's Avatar
touchdown
touchdown is offline
Received 1,662 Likes on 948 Posts
I would check the exhaust since you just changed them.
Old 02-27-2017, 06:06 AM
Back-n-Black's Avatar
Back-n-Black
Back-n-Black is offline
Betting on exhaust leak when starting cold....Pipes heat up and expand and get quite.
Old 02-27-2017, 06:25 AM
josame's Avatar
josame
josame is offline
Sounds like a lifter to me. I had the same thing, lifter would bleed down after bike sat for a while then pumps back up after running for a little bit.
Old 02-27-2017, 06:31 AM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,632 Likes on 1,177 Posts
The only thing that you've changed recently is the pipes.... that's where I would look.
If you suspect a lifter, try different oil. Spectro 25-60 dino oil is the best I've found when it comes to noise.
Good luck in the hunt
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 03-01-2017, 12:06 PM
myglide's Avatar
myglide
myglide is offline
I have a lifter that does the same thing. Comes and goes.
Quick Reply: What's the ticking?
