Change Soft T ail Front end
here, check it out. you can go to this link and research all the parts that make up a standard, and a fat boy, then compare the two and see which you'll need to procure.
http://shop.outpostalaska.com/oempartfinder.htm
The fork lowers are different on a FXST vs. a FLST. On a FLST, the top portion of the lower legs are taller, to merge with the cowbells. Same year-range lowers will fit same year axles/rims/calipers. Axle/wheel bearing size are what you need to look for. Fork tubes, are the same. Triple trees are different, with threaded bosses on a FLST version, to accommodate the fork "tins". All told, it's simply nuts, bolts, screws, bearings and oil seals.
Rowdyone (05-04-2017)
