Someone PLEASE help
Don't know what to tell you, then. $500 is a crazy low price for a good Evo motor.
I assume the timing cover had been drilled out/replaced before you got it?
No telling what you've got going on here. At least the compression is good, so it should run.
I go back to my a-b-c questions from a few posts ago. In your shoes, with a good compression test, I'd assume for now that the motor is internally sound.
Yes, timing cover was drilled prior to me owning it. I'm going to fool around with it an it more tonight and see if I can figure anything else out.
Ok after messing with it for about 2 hours tonight I'm still having the same issue. I have the rocker covers off and I watch the front cylinder intake valve open then close then tdc is right there. When I set the ignition itself, turning it clockwise til the light turns off I would not be able to get the bolts in to snug it up. It's rotated past that point. Tried firing it and it still blows the fuel out of the air cleaner. I even tried rotating the ignition module upside down and rotating it until the light turns off and I can hear it sparking on the #2 cylinder through the exhaust pipe. So I turned it back around went through the process a 10th time and still same issue. I'm at a loss right now. Don't know what else to try. This would have to be the first time I haven't been able to something like this out. Any other suggestions are greatly appreciated.
I pulled the cam cover one more time. Noticed that with it at 12 o'clock on the pinion the cam mark was also at 12 o'clock. Rotated the engine a full 360 then everything lined up. Is it possible the cam is out of time??
That would be the only thing I have left to try. What's the easiest way to pull the cam out far enough to spin it 180 degrees??
Yes, it's possible that the cam is out of time. That will happen if the cam gear is not oriented correctly to the cam when it's pressed on. That said, since you have a good compression test, I don't think that's the problem.
You should be able to install the ignition module (loose fit in the screws), set the motor to TDC, then adjust the module until the LED goes out. The fact that you can't suggests one of two things: Either you are not correctly finding front cylinder TDC compression stroke, or the timing cup behind the module is loose or mis-installed.
Describe your procedure for finding TDC on the front cylinder. My hunch is that what you think is the compression stroke is actually the exhaust stroke.
