ABS out of calibration ?
Old 06-10-2017, 01:11 AM
psyshack's Avatar
psyshack
psyshack is offline
You answered your own question....
Old 06-10-2017, 02:39 AM
rlh7677's Avatar
rlh7677
rlh7677 is offline
Originally Posted by martinj
But what is the diameter of each of your original (stock) tires? If, for example, the stock front tire is taller than the stock rear tire, in that configuration the front tire would be rotating more slowly than the rear tire would be. Then, when you changed both tires so they were rotating at the same speed, this would throw the ABS calibration off.
I guess, was just hoping someone had an answer that was quicker than researching,that is what I think my problem is and I see after searching there are some products actually made to correct this specifically , Trac max by Thundermax is one and there are a couple more targeting the big front tire crowd to correct the rotation speed differences. This tells me there are issues which are correctable when the ECM gets thrown a curve ball as per tire rotation, Tracmax is targeted at the 14+ but I will call and see if I can get any answers for earlier years. So far all very interesting, thanks for the help, I'll try to post if I get things corrected. Silly me, LOL, upon further research I find the Power Vision tuner ,which I am running, has speedo calibration settings, I will start there today !http://thunder-max.com/Products/TracMax.aspx
Old 06-10-2017, 08:51 AM
skratch's Avatar
skratch
skratch is offline
Received 4,217 Likes on 2,465 Posts
i'm not sure that this is the case. we switched wheels/tires from the stock 18/16 on my wife's bike to the cvo sized 19/18 and the bike threw no codes. as long as you are using the stock Harley sized tires, the 16, 17, 18 and 19 inch front tires are all virtually the same overall diameter. for the rear, the stock 180/65-16 tire has an overall diameter of 25.2'', while the new 180/55-18 has an overall diameter of 25.8'', increasing the circumference of the tire by 1.8'', and the diameter by .6'' (raising your rear .3''). i'm not convinced that that is enough of a difference to cause the ecm to throw a code, especially given that hd uses those same sizes.
Old 06-10-2017, 10:13 AM
martinj's Avatar
martinj
martinj is online now
Received 15,269 Likes on 6,238 Posts
I'm not sure it's the case either. But, if the tire change is the only change the OP made to his bike, it's the logical starting point. In any case, it'll be interesting to see what the OP's solution is.
Old 06-26-2017, 08:42 PM
rlh7677's Avatar
rlh7677
rlh7677 is offline
Default ABS Calibration
Ok, solved the ABS problem for those following. I purchased the rear wheel off of Ebay which was a "new" never used display wheel with the bearings installed, the correct ABS bearing was installed as per the part #'s. The problem turned out to be that the ABS bearing was installed with the part numbers to the outside as you can read them which is what I would have thought to be the correct install, turns out the numbers are installed inward as the correct way which is reflected in the code read, as for the tach code it disappeared with the rear sensor code ! All is well, no ABS light on and no codes all because of a incorrectly installed rear ABS bearing ! Hope this helps someone else also. Thanks for the help and remarks !
kap1 (06-27-2017)
Old 06-26-2017, 08:49 PM
Buelligan666's Avatar
Buelligan666
Buelligan666 is online now
Glad you got it figured out, and returned to let others learn from your experience. Valuable contribution. Thanks!
Old 06-27-2017, 10:16 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,238 Likes on 1,814 Posts
Great, but...
This a lesson on the value of including pictures (even while installed, you can make out the incorrect Orange Out).
This could of /should of been answered on the Post#2 when someone saw the installed bearing. You only have to see it once
TOE_CUTTER
02-07-2018 11:33 AM
Ace07FXDL
Wheels/Tires
01-10-2013 08:31 AM
appling streetglide
Touring Parts
07-20-2012 07:09 PM
103Eagle
07-20-2010 12:12 AM
mdst
04-18-2009 03:33 AM
Quick Reply: ABS out of calibration ?
