Clutch fluid reservoir lid and gasket.
I have been jynxed. My hydrulalic clutch fluid reservoir was leaking and running down the side of the master cylinder. I have read that these are known to leak. I took the cap off and it was over full and spilt brake fluid all over the master cylinder. Luckily no damage as I had a towel ready. I put it on the absolute minimum level and then playing around with the tightness of the cap. Does anyone know how tight it needs to be with a screwdriver. Anyone have any tips for this. I'm sure someone has had this issue before. Is it common for the gasket to be wet ?
If you read in your service manual it states that as the clutch wears the master cylinder will become over full. It's part of the service schedule to check and remove the excess fluid. The manual will also outline the torque spec for the screws. I only use 2 fingers on the shank of the screwdriver.
My service schedule just says check clutch fluid by eye glass. Which it would show full regardless. No the eye glass is about 2/3 full. Which is about minimum. Anyways do you tighten the screws until they just become tight with the screw driver? It's hard to measure 12 pounds as my torque doesn't go that low.
I believe mine is inch pound and the lowest setting is 20. With other markings underneath but they are not labeled so it would be a wild guess to get 12. I tightened it snug and backed it off a 1/4 turn. Do you have to do the same for the brake cylinder (hand and foot) remove fluid after so many miles or is that gernally with the clutch. Sorry This is my first new bike so I'm just trying to learn.
ETA: Don't open them any more than necessary. Opening the reservoir introduces moisture into the system. Dot4 fluid absorbs moisture. Moisture lowers the boiling point of the fluid. On ABS bikes it's believed to be the root cause of ABS module failure.
