Still searching for the right setting on my 944's.
I've had my Progressive 944's for a few months and still can't find the right setting. I have a 2010 Ultra set up like a street glide. I weigh about 180 lbs and ride solo 100 percent of the time so I ordered the standard springs. When I first installed them I used the sag setting as my guide. I wasn't happy with the results so I started trying different settings. I have done everything from 1/8 turns to five turns. I honestly don't think these shocks ride any better than my stock air shocks with a Burly 1 inch lowering kit. I would be curious what settings some of you are using that weigh about what I do. Thanks for your comments.
How many miles? Months, for some of us could be several thousand, for others barely 100. They need time to settle in. I bought mine used, but in new condition. I ran them for 5k on my Electra, and another 13k on my Road Glide. I have them mounted adjusters down (shouldn't make any difference) and set at 3 turns. I'm 220 and the ride is smooootthhh. Standard rate springs. I used a center punch and marked the adjuster and the shock body to make it easier to tell how far I have adjusted them. Monotubes up front with one clip. Rides like on rails.
Received 4,366 Likes
I used a silver markie to mark the adjuster and the shock barrel. I have the (44 HD series and weigh near 250, I have 1 1/2 turns solo and 3 1/4 two up, I think we are pretty close to our set up. Try half turns then work down to quarter turns, you'll soon find it. I have a rubber strap wrench that makes it a bit easier.
I'm 225ish & ride solo 100%. When I got my 944s I could never seem to get them right, always seemed too stiff. After a lot of tweaking I discovered they weren't stiff enough.... I was riding on the bump stops a lot. Sent them off to Progressive & they changed the springs to HD (for free I might add), bingo.... now I was using all of the suspension travel. I have found many times over the years that folks' problems with shocks is having them too soft in search of a softer ride. Try setting them full stiff & working your way back from there instead of the other way around.
I've since changed to Ohlins because.... the internet says you should have ohlins They are about the same amount above 944s that 944s are above stock.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
They are only as stiff as the spring you select. And spring selection is critical. The counter intuitive solution to your problem is to get the HD spring vs the standard. At your weight, you are probably either bottoming out (rough ride) or have so much preload dialed in that it eats up the progressive aspect of the spring (rough ride).
I'm not sure what amount of travel you have, but lets say 3 inches. You should set sag to be 1 inch. That accounts for you and the bike. So get the bike off the ground and measure eye to eye. The get the bike on the ground, sit on it and get the bike off the stand, full weight of you and bike on shocks and measure eye to eye. Yes, you need help doing this. Adjust preload until it's 1/3 of unladen (total) travel. Then secure a tie wrap to the piston (anywhere but the bottom). Go riding. When you come back, is the tie wrap jammed into the bumper? Or is it riding well above the bumper?
Setting sag is just a starting point. You need to get it so that the tie wrap is just above the bumper, which means you are using almost all of the travel the shock offers without bottoming.
The key is - if you are turning more than 6 turns (an estimation) you are running too light a spring. Ideally, you would add very little preload to a progressive (type - not the name) spring so that you have the most of the softer spring rate to eat up the small bumps. I ran the standard spring on my Street Glide, albeit 444s. I wasn't thrilled with the ride. I changed up to HD springs and it's smooth as silk.
