found a surprise - not too happy
Old 12-31-2017, 05:45 AM
Killa's Avatar
Killa
Killa is offline
Yep,, what Hey Man said.
Another two inches would do it,,,what she said.
Old 12-31-2017, 07:37 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I would weld it.
If it breaks again then get a new bracket.
Old 12-31-2017, 08:59 AM
nevada72's Avatar
nevada72
nevada72 is offline
Received 25,623 Likes on 12,011 Posts
Had a bracket there for my D&D pipe. It would work itself loose all the damn time no matter what I did. First time I noticed it was a few thousand miles after the dealer installed it, so it wasn't just me. I ended up just leaving it off.
Old 12-31-2017, 09:13 AM
OlAndrew's Avatar
OlAndrew
OlAndrew is offline
The tapping is not from the top, I hunted all over with a stethoscope probe. The oil is from a leaky oil cooler fitting, since replaced, but a wash didn't get in there. That's a breather hose, but its never spit a drop. I got lucky, I guess. Thought about just leaving the bracket off, but I figured Harley wouldn't have spent the money to put it there if ya didn't need it.
This thing gets ridden nearly every day, so it ain't in show bike condition by any means.
Old 12-31-2017, 09:30 AM
nevada72's Avatar
nevada72
nevada72 is offline
Does the sound change when you apply the rear brake? Had a rubber muffler mount (under the bag) that dried out or something and it made a helluva racket.
As far as leaving the bracket off, I ran the bike for about 30k more miles with no issue. I just figured that, as others have said, the rubber mounted engine jumping around in the frame must really put a lot of stress on that mount. By removing it from the equation, less stress on the pipe as well. But probably more stress elsewhere like the exhaust studs, which could be bad.
Old 12-31-2017, 01:11 PM
hvacgaspiping's Avatar
hvacgaspiping
hvacgaspiping is offline
Received 16,369 Likes on 8,431 Posts
Set out to change my clutch cable. A curse upon the house of whoever designed the thing that you have to pull the exhaust to get to the clutch cover. Found this when the heat shields came off:
THe clamp was broken, too. Guess I'll dig out the buzz box and burn a stick on the bracket ( I disconnected the ECM and the battery). Wants a new clamp, though. Wouldn't trust a weld on that.
The break in the clamp was half rusty and half clean, so there was a flaw in the metal there. Got no idea how the bracket got broken.
Maybe the tapping I've been trying to trace will go away when all that's fixed.
`Looks like something was vibrating/rubbing against the housing. Maybe your pipes, and also rubbing against the cable?
Old 12-31-2017, 02:46 PM
Hoginedgewood's Avatar
Hoginedgewood
Hoginedgewood is offline
Received 1,192 Likes on 653 Posts
I’d weld it and extend the vent hose.
Old 12-31-2017, 06:27 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
That is one thing I do not miss. Having to replace clutch cables. I feel for you.
Old 01-02-2018, 05:48 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
I had that bracket break on another bike. It is cheap to replace. It did make a lot of noise that was eliminated after replacing it.
Old 01-02-2018, 10:01 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,857 Likes on 1,288 Posts
Stock part number for the bracket is 65678-85C. We have some if Harley doesn't.
Johnyboy05
Exhaust System Topics
07-23-2018 05:21 PM
Keithhu
10-27-2013 05:42 PM
code3smith
08-29-2013 08:03 PM
editbrain
04-25-2012 04:42 PM
xdanman
06-06-2011 05:31 AM
Quick Reply: found a surprise - not too happy
