found a surprise - not too happy
Set out to change my clutch cable. A curse upon the house of whoever designed the thing that you have to pull the exhaust to get to the clutch cover. Found this when the heat shields came off:
THe clamp was broken, too. Guess I'll dig out the buzz box and burn a stick on the bracket ( I disconnected the ECM and the battery). Wants a new clamp, though. Wouldn't trust a weld on that.
The break in the clamp was half rusty and half clean, so there was a flaw in the metal there. Got no idea how the bracket got broken.
Maybe the tapping I've been trying to trace will go away when all that's fixed.
That's one bad thing about them rubbermount Harleys, they're hell on exhausts.
You can weld it, but it'll probably crack right at the weld where the metal becomes more brittle from heat. I'd recommend a set of short shots, to minimize leverage on the engine mounts for the exhaust.
And it'll sound cooler.
Received 8,251 Likes
Maybe the tapping is coming from the top end & not the bottom?
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
What the heck is that cut off braided line for? A breather hose? Looks like it's just blowing oil all over your frame and wiring. Nasty.
big papa AZ (12-31-2017)
