okay now i’m getting upset with this bike. i tightened and retightened the ground from the battery to the frame. i rigged the injectors up off the bike and they’re squirting gas. the compression is good and it’s getting spark. what gives??
Make sure you check the wiring into the injectors. Make sure it is long enough and not stretched or kinked or broken.
It can only be so many things. Engines need fuel, air, and spark to run. Has to be one of those issues. Start easy and eliminate. Then move on. You will find it.
ive already drained the gas and put new gas and seafoam in and that didn’t do much. i just checked the spark again and it was pretty weak, barely made my tester light up. this is all started after riding in the rain, someone suggested water was sitting in the ignition wires. when they say ignition wires are they referring to the spark plug wires to the coil? or could the coil itself be bad with less than 5000 miles? it hasn’t thrown the check engine light either
