Highway pegs...
Old 06-15-2018, 10:51 AM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
itll work, ive done a few sets over the years
Old 06-15-2018, 11:03 AM
LonestarXL's Avatar
LonestarXL
LonestarXL is offline
Lube, a BFH if you don't have a rubber mallet, and a piece of leather of some sort to protect the pegs when you whack on it. The spacer should have some curve to it; make sure the curved part is facing inward, if that makes sense.
Old 06-15-2018, 11:20 AM
Road Star's Avatar
Road Star
Road Star is offline
Seems to me, the flat part of the spacer should be facing the flat part of the bracket. Otherwise, the spacer would rotate.
Old 06-15-2018, 01:55 PM
LonestarXL's Avatar
LonestarXL
Yes, that's true, from one perspective. However, the curved part I'm talking about is, if you lay the spacer flat (or at least mine are this way), there's a "bend" to the washer, so that it provides a little tension. I always put the "curved" side facing the peg, and not the bracket, if that makes sense. Of course your washers may be perfectly flat.
Old 06-15-2018, 02:11 PM
JerseyDoug's Avatar
JerseyDoug
JerseyDoug is offline
I do the same thing. OP, it will fit, just takes some finessing.
Old 06-15-2018, 05:40 PM
pei_guy's Avatar
pei_guy
pei_guy is offline
Just bought a set of pegs yesterday and am installing them now, ran into the same trouble. Thanks for the tips!
Old 06-15-2018, 07:32 PM
Road Star's Avatar
Road Star
I'm still trying to figure out how to mount these so they are comfortable and not in the way of the brake pedal.
Old 06-16-2018, 07:08 AM
Jay_FLHXS's Avatar
Jay_FLHXS
Jay_FLHXS is offline
I bought at set like this on Ebay and it came with two different thickness spacers. I used the thinner spacers and it still took some time with a rubber mallet to get them in.
Old 06-16-2018, 09:59 PM
sechracer's Avatar
sechracer
sechracer is offline
Also don't forget the set screw is the bottom side. So you can set stop height/level.........
Rking80
Touring Parts
02-08-2019 07:28 AM
Burbur2
09-10-2018 07:37 PM
fatmanontwowheels
Touring Parts
07-22-2018 07:12 PM
115th FLHXS
06-15-2018 06:46 PM
QC
01-07-2017 11:53 AM
Quick Reply: Highway pegs...
