Cooling fan install
Cooling fan install
The cooling fan kit (H-D Part # 91550-00c) is only intended for touring models. Why can't it be installed on a Softail?
I ride a 2006 FLSTC in the LA area and the traffic is ugly. My oil temp regularly gets up to 270. Even "splitting lanes" I sometimes have to get off of the freeway to let the engine cool down, because it will be running rough.
I am open to thoughts. I just can't afford a $380.00 part that won't work.
RE: Cooling fan install
ORIGINAL: DrPAPA
The fan looks like it mounts to the head bolts. Looks like the bottom bracket mounts to the primary cover bolt. You would probably at the worst have to remake the brackets. It says Twin Cam and 1340 engines.
You know you can mount an oil cooler and get anywhere from 20º to 25º engine oil temp drop.
Before I would spend that much for a fan i would look into the coolers. I have one on my Low Rider. It is a billet aluminum from Wimmer. It uses the Jagg temp controlled oil adapter. Easy to install. The adapter goes under the oil filter.
I haven't tried it but if you have a crash bar. You drill the end plates of the bar and mount oil fittings in the ends. It uses the bar as a cooler. there are folks that swear by it.
Here is my setup. Several days this week in Memphis it was in the high 90's. My temp did not go over 210º.
OK, but you have to be moving for the oil cooler to work. In LA traffic, the fan might be the better solution. An oil cooler will do nothing in a traffic jam or bumper to bumper traffic. And that oil cooler must be put on correctly or you will end up with the problems mentioned by others who screwed it up.
Also, why do you think that 270 means you have to get off the road? The '06 engine is smaller than the '07. I know your legs are hot, but that engine can deal with 270 for sure, IMO.
ORIGINAL: thelawdoc
ORIGINAL: DrPAPA
http://cgi.ebay.com/ebaymotors/Cooli...QQcmdZViewItem
Note: If you click on sellers other items link, this guy has also sells a nice looking fan driven oil cooler setup.
i seen thefans on ebay that install in the horn location.with the horn. looks cool!
The HD cooling fan kit may draw more electrical current than the Softail charging system is designed to handle, the touring bike have larger alternatorsand the electrical harness will not have the engine management circuits to activate the fan that the touring bike have. Psycho's suggestion may be a good compromise and the oil cooler regardless of design will add to the bike's oil cooling efficiency regardless of design. Whether it is enough to resolve you concerns is open for debate.
Good Luck,
FBL
Good Luck,
FBL
