Motorcycle Receiver Hitch Hauler
I have 3 concerns-
1-I have no clue about if belt coasting or pulling the trans for a long ride will be ok .
Probably........
Next, i have no clue if with just the main shaft turning it will lubricate itself corrctly.
3,- lastly there is no positive lock on the unit to hold it up, just the threads.
I think it needs an over-center something. or a chain tie dwn so if the threads strip it will not drop the front wheel on the ground.
Probably........
I have 3 concerns-
Probably........
Probably........
Received 14,658 Likes
Uncle Larry (10-30-2018)
Do you have an opinion/experience on that product or you would rather slam someone behind your keyboard with no substance?? Really that wasn't at all useful.
If you can believe everything your read, "all steel construction allows for this unit to haul bikes with a curb weight of up to 1000 lbs".
Received 5,388 Likes
OP's rig looks like it would be "maybe ok" for lightweight dirtbikes, but not really heavy duty enough for a 1000 pound behemoth. Besides, anyone here ever try to lift a front wheel on a bagger to put in a wheel chock? Without the bike falling over? Also that set-up is worthless if you have a flat tire. Either end, but as most of you know, the rear tire is usually the one that gets the nail/screw.
Your Dealer will not do rides?
What does that mean?
As in "come to get it?"
You think it is a Ferrari?
I have No Clue why you want to take your Dyna to the dealer anyway.
WTH is wrong with it? (that you have to go to the dealer all the time?)
Shet two miles dwn the road?
You could have it there before you found the keys to your car.......
