What am I missing?? 117 build
Old 11-01-2018, 02:38 AM
Tattooed Mick's Avatar
Tattooed Mick
Tattooed Mick is offline
Default What am I missing?? 117 build
Hey all. Getting ready to complete my install and wanted to lean on the experience here to help me see what I have overlooked.
Bike started out as a 2014 Road King. Love this bike. Decided to convert it to a Street Glide when I found a screaming deal at an insurance auction. Frame was cracked and bent so they totaled it out. Everything else was 100%.
4015 miles on the bike. So I stripped all the good stuff and am selling whatever's left that I don't need.
Had the plastics and tank painted to match. Ran the FLHX wiring harness and began building the motor. Am going to swap the front end and bolt up the ABS pump and module. Touchscreen radio connected to the Wild Boar SG audio system already installed.
What I've done so far:
S&S 117 big bore kit
Darkhorse bottom end including:
  • Upgrade all bearings - Balance/Blueprint lower end and assemble complete
  • 4.375" stroke flywheel set 07-later
  • Centerless ground 1.6710" 2-hole crankpin
  • Darkhorse Rod-roller bearing Set .2164"
  • TC Competition H-beam Connecting Rod Set
  • Balance new crankshaft assembly
  • Darkhorse pro-plug
  • Weld crankpin
  • Race,Inr,R Main Brg,Pkgd,
  • Pinion Clip
  • Man O' War 4-3/8" Crankshaft
  • Assemble *Balanced & Bleprinted with Competition Rod
  • TWIN CAM TIMKEN BEARING CONVERSION UPGRADE A -MODEL
  • Case boring to 4.322" x 1.545" with step to 4.162 x 2.250"
  • HBR Main Timken Bearing
  • Bearing Roller
  • DH SPROCKET SHAFT SPACER
  • Motor Sprocket Shaft Seal
  • JET PISTON ASSY WITH O-RING
  • Cam Bearing 06 Dyna, 07-08BT
  • THRU-BOLT KIT TC BIG BORE CASES
  • Bearing Retaining Plate Screw
Revolution Performance Monster head package:
  • CNC port work
  • CNC valve job with guides and intake seats
  • New 2.000" intake valves
  • New 1.630" exhaust valves
  • New .675 max lift springs
  • New valve guide seals
  • TP Engineering Roller Rockers
S&S Gear Drive Cam kit with Andrews 67HG's
Feuling roller tappets
S&S adjustable pushrods
Evolution Industries compensator eliminator
Baker 1.5" oil pan
Baker Primary Chain Tensioner
Throttle Hog 58mm throttle body
Fueling 5.3 g/s injectors
Trask 58mm a.c.
D&D Boarzilla
Barnett Scorpion Lock-up Clutch & Basket
and that's it... so please, help me punch holes in this build. What am I forgetting?? What did I overlook??
Old 11-01-2018, 05:44 AM
joe40x's Avatar
joe40x
joe40x is offline
Go with S&S tappets instead of Fueling for obvious reasons.
Old 11-01-2018, 05:57 AM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
You mentioned "port work".........
But that means nothing without at least some pics
RINGS ,Piston Rings!
Spend the money on low drag rings.It is the best money you can spend.
A lot of shops overlook this little trick.
Why OH why push and pull 30 lbs when you can do the same numbers with 9 to 12 lbs?
why turn it all into heat /friction?
AND
the BIG one How is this bike to be proposed?
The longer haul or all that you can reasonably get which means shorter lived valve related stuff.
Are the guides cut trimmed?
Guide bosses have a nice boat to them??
It is all a slippery slope and it looks like you have a good handle on it all.
Old 11-01-2018, 06:04 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
09 YELLOWBIRD is offline
I will add, make sure you have a REAL Turner (TTS, PV, JMHO in that order) a REAL Dyno Tune and sum thing to wipe that chit eating grin of your face!
***Warning- Good luck, been 3 years and I still can't find anything to wipe the grin of my face!
YB
Old 11-01-2018, 06:16 AM
Kingglide549
I wish we had more Hot Rod threads here..........
Everyone gets all tied up with the dumbshet crap.
Dehammer (11-17-2018)
Old 11-01-2018, 09:16 AM
Tattooed Mick
YB
I had planned to use Techno Research perform a wide band o2 tune on it. Then off to Nitro's in Pasadena for runs on the treadmill. I believe they also are a technoresearch shop.
Old 11-01-2018, 09:20 AM
Tattooed Mick
AND
we installed the S&S rings that came with the 117 cylinder kit. Honestly didn't think about upgrading them. I will call Revolution Performance today and inquire about the guide bosses, I would assume, but then again.... Excellent point, and one I didn't think to double check.
bike is my daily "driver". Only car I own is a 1963 DeVille Convertible that gets driven for the pure pleasure of it. Lots of long trips across country and into Canada.
Old 11-01-2018, 09:26 AM
Tattooed Mick
I've gotten tons of info off forum threads on builds. Learned a long time ago to know what I dont know. Lol
GaryLC's Avatar
GaryLC
GaryLC is offline
I'd add an oil cooler if you don't already have one.
Old 11-01-2018, 09:29 AM
Tattooed Mick
motor is already assembled but they are easily changed. Why you recommend the S&S tappets over Fueling?
Quick Reply: What am I missing?? 117 build
