Is there any risk in removing and reinstalling a tire?
I want to install metal valves on my wheels to use some Fobo TPMS valve caps. (they work great btw, I have a set on my FXR) Obviously the tires need to come off to change the wheel valve. I'm wondering if it hurts the tire at all, removing and reinstalling it. I'd hate to have to wait until its time for new rubber to use the TPMS.
Thanks
Thanks
Received 14,178 Likes
Mchad (02-21-2019)
Mchad (02-21-2019)
Mchad (02-21-2019)
I replaced the valve stems on my bike without removing the wheels.
With bike lifted on a jack.
Remove the inner valve stem and use a large c clamp and a block of wood to break the bead on the tire.
I just broke the old stems off and retrieved the base of the stem from inside the wheel.
I poked a piece of wire through the valve stem hole to guide the new stem in place.
Not much fuss, I had both done in half an hour.
You could do it on a jack without removing the tire, but It's way more difficult. It'll take longer to pull and reinstall the tires than to install the new stems.
Mchad (02-21-2019)
Good deal, thanks for this. I will proceed. I'll post the results.
