Can't seat beads on new tires
Just mounted Michelin commander II's on the dyna and what a pita doing it manually by yourself. Anyway finally got em mounted but the sides are kinda close together and not seating when trying to inflate. I've tried ratchet straps on center of tire to push side walls out but no luck so far.
Anyone else have this issue and how did you fix it? Thanks
Changed many tires myself either because I had to or for a while could not afford to pay someone with the right equipment . No fun some time . Try it when it is real cold. Now I let them do it. For many years father in law insisted we did the farm tires our self also that was fun.
I do not recommend the either trick.
cacomly (02-25-2019)
I know it's common sense, but do you have the valve core removed? I've seen a lot of people try to seat the bead with the valve core still installed.
pretty sure you're talking about 'ether'. in the military, at my first duty station, I was helping change a tire on a piece of heavy equipment. the tire was taller than me. split ring type. the sgt was having all kinds of problems getting the bead to seat. tried ether a couple of times, but never quite got the 'woomf' blast needed. so he used more. a little too much. the split ring came off and ended up going through the roof of the building. luckily, no one got hurt. it was a couple of years later that they started mandating tire cages.
Kingglide549 (02-22-2019)
The following 2 users liked this post by Kingglide549:
Bonnie Storm (02-22-2019),
Hey Man (02-24-2019)
